Electronics
Electronics
External B-Field in shape possible?
    • p.abt
      I am interested in simulating the influence of an external magnetic field on a custom steel shape I have designed.
      Is it generally possible to create a homogeneous magnetic field and place my designed box within it? I want to observe how much of the magnetic field is deflected by my box, which acts as a shield for a transformer.
      Is a 2D or 3D simulation better here?
      Could you recommend useful resources for learning how to perform this simulation in ANSYS Maxwell? I am a complete beginner.
      Thank you in advance.
      This is the shape I want to analyze
    • Ivonne Marti
      I advise to use 3D. The homogeneous magnetic field can be recreated using the boundary condition “Zero Tangential H-Field” (flux normal to the surface) or “Tangential H-Field” (flux tangential to the surface). These boundaries are available in the magnetic solver Magnetostatic and Eddy Current.
      If you use the magnetic transient solver, the boundary “Zero Tangential H Field” is available.
      Usually, the boundary will be applied in the appropriate surface of the Region (calculation volume).
      You can find information about the different boundaries in:
      • ·       Maxwell Help > Assigning Boundaries and Excitations for 3D Designs > Magnetostatic Boundaries and Excitations > Magnetostatic Boundaries
      • ·       Maxwell Help > Assigning Boundaries and Excitations for 3D Designs > Eddy Current T-Omega Boundaries and Excitations > Eddy Current T-Omega Boundaries
      If you want to create the magnetic field without using boundary conditions, please look at the following solution:
      How to create uniformed external magnetic field in Maxwell 3D? | Ansys Knowledge
