TAGGED: beams, error-explicit-dynamics, frame, velocity
January 10, 2025 at 12:26 pm
January 10, 2025 at 12:46 pm
ErKo
Ansys EmployeeÂ
Hi
I would suggest to place the wall exactly next to the frame so they are just touching (we do not want to resolve the travel time in explict).
See here how to set it up (see how the bc/displacement are defined as they allow the car to move towards the wall):https://www.youtube.com/watch?v=EhTO0_ovhnA
All the best
Erik
January 10, 2025 at 1:20 pm
January 10, 2025 at 2:27 pm
ErKo
Ansys EmployeeÂ
Hi
Place the wall a bit closer (gap should be much less than 27778 mm/s*0.001 s ~ 27 mm , so say 5 mm or so).
Then:
Can you show the frame displacement at the simulation end time (0.001 s) , because your sim. goes only up to ~1E-8 so perhaps it has not run fully (due to error, etc.) – we want to see if it has actually travelled the gap between the frame and wall.Also show the stress contour of the wall to see if it deflects.
All the best
Erik
January 10, 2025 at 2:49 pm
January 13, 2025 at 12:06 pm
mohan.urs
Ansys EmployeeHey,
Can you check this course once and see if you have the setup right. The course is very similar to what you are doing.
https://innovationspace.ansys.com/courses/courses/explicit-analysis-of-a-chassis/?template=academic
Let me know how it works out.Regards,
Mohan Urs -
January 14, 2025 at 11:19 am
dciesielski0103
Subscriber-
January 15, 2025 at 2:38 pm
mohan.urs
Ansys EmployeeHey, Please check this Knowledge material from ansys for this query -Â
The equivalent stress plot of beam elements shows the value 0 even these beam elements are actually deformed and stressed. How do I get these information from Explicit Dynamics system? | Ansys KnowledgeRegards,
Mohan Urs
6485
