Ansys Free Student Software
Error while trying to run
    • mysticalmanish11
      I tried to run ANSYS workbench 2024 Student version but it is giving "An unexpected error has occurred: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception." error.
      Upon further details it says following
      System.MissingMethodException: Method not found: 'System.Collections.Generic.IEnumerable1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.
      at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e)
      at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context)
      at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary
      2 options)
      --- System.Reflection.TargetInvocationException: Failed to load language 'IronPython 2.7.4': Method not found: 'System.Collections.Generic.IEnumerable`1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.
      at Microsoft.Scripting.Runtime.LanguageConfiguration.LoadLanguageContext(ScriptDomainManager domainManager, Boolean& alreadyLoaded)
      at Microsoft.Scripting.Runtime.DlrConfiguration.LoadLanguageContext(ScriptDomainManager manager, LanguageConfiguration config)
      at Microsoft.Scripting.Runtime.DlrConfiguration.TryLoadLanguage(ScriptDomainManager manager, AssemblyQualifiedTypeName providerName, LanguageContext& language)
      at Microsoft.Scripting.Runtime.ScriptDomainManager.GetLanguageByTypeName(String providerAssemblyQualifiedTypeName)
      at Microsoft.Scripting.Hosting.ScriptRuntime.GetEngineByTypeName(String assemblyQualifiedTypeName)
      at Ansys.Co
    • Rajeshwari Jadhav
      What's the release no? Can you rename the Ansys folder (%appadat%) to Ansys.old and try again?
    • trinhtt
      try reinstalling ANSYS and ensure required .NET frameworks are correctly installed.
      geometry dash
