Error using VOF Coupled with Level Set Function Model with pseudo time method
    • tardir
      I am modeling two-phase upward annular flow using the VOF coupled with the level set function model, a coupled volume fractions pressure-velocity coupling, and a pseudo time method. Whenever I run the simulation, I get an error message:
      Error: rp-var-value: undefined variable
      Error Object: lsfun/pseudo-cycle-type
      Error Object: #f
      Does anyone know what could be causing this error?
      Try with a full transient solution, I suspect it's not intended to work in pseudo-transient. It's not a widely used option, and to a point was an evolution step in VOF that wasn't taken very far.
