TAGGED: 3d-mesh, ansys-autodyn, Ansys-Mesh, help, help-me
February 13, 2025 at 2:44 pm
ahan20
SubscriberHello, I have a model of a room which contains heat sources, and I meet the following error code.
Error: Build Grid: Aborted due to critical error.Â
Error Object: #fTo my understanding, this is affected by the mesh quality, but as seen in the attached images, the skewness and aspect ratios should not be a problem.Â
Where might I look to find the source of this problem? I'm at my wit's end.
February 13, 2025 at 3:22 pm
Forum ModeratorWhat does the section plane look like? Cell quality means your cells are OK, however mesh quality also includes mesh resolution within a domain.Â
February 13, 2025 at 3:43 pm
February 13, 2025 at 3:50 pm
Forum ModeratorIt doesn't need to line up, but does need to not overlap: ideally it will line up. You've not split the room with the contents.Â
February 13, 2025 at 3:52 pm
ahan20
SubscriberThis should be done in space claim, right? How would I do this?
February 13, 2025 at 3:54 pm
Forum ModeratorYes, look at "Share Topology".Â
February 13, 2025 at 4:00 pm
February 13, 2025 at 4:11 pm
Forum ModeratorCheck for duplicate bodies. You may also want to update to 2025R1 as Share Topo has been improved significantly.Â
