January 20, 2025 at 8:49 am
yogesh.babu
SubscriberHello,Â
I want to use an encrypted SMA Connector model as a .aedt file from Würth Elektronik (WE) in one of my HFSS simulations. However, it gives the below error. When I contacted WE, they could not help and told to contact Ansys. Could you please help me with this? I am using Ansys Electronics Desktop 2024 R1. SMA connector article number: 60312202114514 -
January 24, 2025 at 12:14 pm
Praneeth Munaga
Ansys EmployeeHi Yogesh,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please share the link from where you are trying to access the 3D component to help us serve you better.
Kindly note that if the component needs to be updated with a support version then WE team can only update it as it is encrypted.
There are few SMA connector 3D components available from WE in the 3D component library. If it interests you, then one general SMA connector 3D component is available under 3D components library > HFSS > Surface Mount Devices.Â
Best regards,
Praneeth.
Click here to join Electronics Community and build a network.
5934
1306
