Error in CFD post
    • pegah.mehrabian
      I have a simulation that includes 20M elements for the mesh (ANSYS 2023R1). As you can see, every module has a green tick, but I can't get the results in CFD-Post. It gives me the following error:
      Application Error in CFD-Post: WARNING
      Case CFX 1 doesn't contain any mesh or results data that is valid for post-processing.
      I tried it on my machine and HPC as well, but it still gives me the same error. Do you have any idea what I should do?
      If you look in the folder can you find the CFX model files? If so, copy these into another folder and try and open there. Did you previously run the model on your computer?
    • pegah.mehrabian
      Yes, and Yes. I copied them into another folder and It doesn't work. I ran the simulation before on my machine as well as HPC. This has happened regularly since I used ANSYS 2023 R1.
      Is there anything useful in the .out file?
    • pegah.mehrabian
      Could you please ask more specifically?
      What does the .out file contain? It'll usually have some warnings or error messages that may be more diagnostic.
Viewing 5 reply threads
