Electronics
Electronics
Error in Ansys Maxwell 2024R1 for WPT Coil (“Error in calculating the conducti)
    • moral137
      I am simulating a WPT coil in Ansys Maxwell. It has Litz Wire.
      The model was given as a STL file, I am able to setup the simulation but it runs out of memory.
      I extracted the centerline of the cable an drew it myself inside Ansys (so the model is now composed of centerlines drawn by straight lines and then adding a circular crossection).
      I am getting the following error (which I don't get with the STL file) : "Error in calculating the conduction paths. The most likely reason is that the mesh of the source conductor is wrong."
      I have tried changing mesh settings (slide to make it finer and less fine), I pass the validation check, I can correctly identify the conduction paths. What could be going wrong here?
      Thank you! I will be looking for any answers.
    • MirandaH
      It's pointing at the conduction path, does it run through without error if you are using regular copper wire (not Litz)?
    • moral137
      No, using copper generates same error.
      • MirandaH
        Thanks for trying that, it might relate to the geometry. Can you make all three coils closed loops?
