Dynamic Mesh DEFINE_GRID_MOTION UDF Errors
    • jdch232
      I'm attempting to model a flexible flat plate using using a UDF with the DEFINE_GRID_MOTION macro in Fluent 2025 R1 student through Workbench. I'm new to using UDFs, though I have gotten some working. I'm defining a flexible plate as one that alternates between flat and bulging outwards in several peaks over time.
      I'm using the following equation for y-velocity: Vy = (5pi/33) * (sin{2pi * t - 1.5} + 1) * sin{10000pi * x}
      This results in a plate alternating between flat at 0s, 1s, 2s, ... and a flexed at 0.5s, 1.5, 2.5s, ..., as shown below.
      I'm using the following c code:
      #include "udf.h"
      DEFINE_GRID_MOTION(flexible_wall_velocity, domain, dt, time, dtime)
        Thread *t;
        face_t f;
        Node *v;
        real NV_VEC(velocity);
        thread_loop_c(t, domain)
            // Loop across faces in wall
            begin_f_loop(f, t)
              // Loop across nodes of face
              f_node_loop(f, t, v)
                // Current node's coordinates
                real x_coord = NODE_X(v);
                real y_coord = NODE_Y(v);
                // Calculate velocity based on x_coord and time
                velocity[0] = 0;
                velocity[1] = (5 * 3.14159 / 33) * (sin(2 * 3.14159 * time - 1.5) + 1) * (sin(1000 * 3.14159 * x_coord));
                // Update node's position from calculated velocity
                NODE_X(v) += velocity[0] * dtime;
                NODE_Y(v) += velocity[1] * dtime;
            end_f_loop(f, t)
      When I compile the code in Fluent I get this warning:
      "warning: ordered comparison between pointer and integer ('Node *' (aka 'struct _tg_node_struct *') and 'int')
      I've looked into this and found it's saying I'm comparing a pointer variable and an integer. Though I'm having trouble seeing where.
      Then when I create the dynamic mesh on the plate, I get this warning:
      "Warning: incorrect cg motion UDF flexible_wall_velocity::libudf on zone 10 (assuming no motion)"
      This confuses me as I'm not using the CG Motion macro. Does anyone have any advice or direction I could take?
    • Mark O
      Please see the example for DEFINE_GRID_MOTION in the Fluent Customization manual. It is not f_node_loop(f, t, v). It is
      int n;
      f_node_loop(f,t,n)
        v = F_NODE(f,t,n);
    • jdch232
      Yes I was able to get it working. For anyone who might find it helpful, this is the code that ended up working:
      #include "udf.h"
      #include "math.h"
      #define PI 3.14159
      DEFINE_GRID_MOTION(dynamic_wall_motion, domain, dt, time, dtime)
          Thread *thread = DT_THREAD(dt);
          face_t f;
          Node *v;
          int n;
          real x, y, dy;
          begin_f_loop(f, thread)
              f_node_loop(f, thread, n)
                  v = F_NODE(f, thread, n);
                  if (NODE_POS_NEED_UPDATE(v))
                      x = NODE_X(v);
                      y = NODE_Y(v);
                      dy = (1.0 / 80000.0) * (sin((20000000.0 / 3.0) * PI * time - 1.5) + 1) * -cos(10000.0 * PI * x);
                      NODE_Y(v) = dy;
                      NODE_POS_UPDATED(v);
          end_f_loop(f, thread)
      Just plug that into the dynamic mesh and apply it to whatever boundary you're moving
