November 21, 2024 at 9:46 amLukas JanicekSubscriber
why is SpaceClaim not loading DXF correctly? The dimensions and arrows are small, it looks like some things are missing. In other software everything works fine. I am attaching a PDF as well, where you can see how the drawing should look like.
PDF: https://www.dropbox.com/scl/fi/ax7d7h7ol4f6hal8mrrwk/0LH225.pdf?rlkey=wc4yagqvgwt7zfdzfks687w6a&st=ccb7a58b&dl=1
Thank you.
Lukas -
November 21, 2024 at 11:47 amRobForum Moderator
Staff are not permitted to open attachments or download links. Please post images of what you're expecting.
November 21, 2024 at 12:02 pm
November 21, 2024 at 12:08 pmRobForum Moderator
Is that a solid or line drawing? Check the Disco import options as it may or may not read everything.
November 21, 2024 at 12:15 pmLukas JanicekSubscriber
It is DXF!
November 21, 2024 at 12:59 pmRobForum Moderator
Last I used AutoCAD it was 2d line. Hence me asking.
November 21, 2024 at 1:20 pmLukas JanicekSubscriber
It's an exported 2D drawing in DXF (from a software unknown to me). Other software has no problem with readability of values and other elements. The only problem is in SpaceClaim.
November 21, 2024 at 3:51 pmGovindan NagappanAnsys Employee
Hi Lukas,
Spaceclaim is a modeling tool where we prepare geometry for FEA/CFD/EMAG simulations. Are you able to create surfaces from the imported dxf and build the geometry for your simulation?
Spaceclaim has tools to create detailed drawings if needed, but the primary purpose is to prepare models for simulation.
November 22, 2024 at 8:03 amLukas JanicekSubscriber
I'm reporting an import error. If you can't advise me how to adjust the settings to load correctly, please forward this issue to the development team.
Our customers work with imported DXF very often.
Thank you.
November 22, 2024 at 3:22 pmMissy JiAnsys Employee
Hello Lukas, thank you for reporting this, and could you please submit a support ticket case, and we will be able to relate this to the customer and account when it is implemented or fixed, so you will be updated on the status. Missy
1116
468
440
225
201
