August 23, 2025 at 12:47 pm
subra284
SubscriberHi all,
I have been trying to simulate the break-up of a droplet as it passes through a micro-constriction using Fluent. I am using the Volume of Fluid (VOF) model. Unfortunately, the droplet does not break-up even in cases where it should have been based on the experimental data I have. I am wondering if anyone here has done something similar to see droplet break-up. Below are my simulation parameters, feel free to weigh in:
- Domain: Microfluidic (cross-section is 1 mm x 0.1 mm, inlet to constriction = 4 mm, constriction to outlet = 6 mm, total length = 10 mm)
- Type of flow: Multiphase (water in oil)
- Primary phase: oil (continuous phase)
- Secondary phase: water (dispersed phase)
- Model: Volume of Fluid
- Formulation: Explicit with Sharp interface
- Physical parameters -- density, viscosity, surface tension -- set based on experimental studies
- Boundary conditions based on experiment
- Oil mass flow rate at the inlet
- pressure-outlet (P-gauge = 0)
- no-slip walls with contact angle with respect to water = 180 degrees
- Pressure-velocity coupling: PISO
- Discretization methods
- Gradients: Least Square Cell Based
- Momentum: Second Order Upwind
- Volume Fraction: Geo-Reconstruct
- Pressure: PRESTO!
- Time discretization: First Order Implicit (because of explicit VOF)
- Adaptive time stepping from 1E-6 to 1E-4 seconds
Please let me know if any of my settings are incorrect to capture droplet break-up. Any help would be greatly appreciated.
Thanks,
Abhi
Viewing 0 reply threads
Ansys Innovation Space
1333
1168
1090
1014
