January 8, 2026 at 1:14 am
JUGYEONG SHIN
SubscriberHi All :)
There is confusion as the discovery licensing scheme changes in 2025.
Previously, Explore mode was divided into real-time analysis using Discovery Simulation licenses, and Refine mode was an analysis using meshes by adding Pro license.
However, the discovery license itself is divided into Pro, Premium, and Enterprise, and the "Current and Voltage Conditions" feature using the Enterprise license is confirmed to be available in both Explore and Refine modes.
However, the functions related to the electromagnetic field (High FREQUENCY ELECTROMAGNETICS) require the same Enterprise license, but are only enabled in Refine mode.
These seem to change the features available for each mode even with the same Enterprise license, so is there an additional Capability Chart divided by mode?If you have one, please share it with me.
Best Regards,
Jugyeong Shin
January 8, 2026 at 5:55 am
Devendra Badgujar
Forum ModeratorHello Jugyeong,Â
I will share it shortly with you. Thanks for reaching out.Â
DevendraÂ
January 8, 2026 at 2:46 pm
Devendra Badgujar
Forum ModeratorHello,Â
Please check this Ansys Discovery 2025 R2 Capabilities chart | Ansys Knowledge.Â
Thanks,
DevendraÂ
January 9, 2026 at 12:55 am
JUGYEONG SHIN
SubscriberHello Devendra,
Thank you for reply :)
I already have capability chart about license. What I want is Capability Chart for Mode, Explore, Refine Mode.
Until the 2024R2 version, there were differences in the functions available according to Mode, and I wonder if there is any data on the 2025 version that summarizes the differences in functions according to Mode.
Jugyeong Shin
January 9, 2026 at 4:05 am
Devendra Badgujar
You can find this in the help doc from here Functional Differences Between Simulation Stages.Â
The capabilities chart shows what is possible with the type of license you have. Also when you solve in Discovery it will inform you when you model/setup the simulation whether that is possible or not in a particular stage/mode of Discovery.Â
I hope this helps. Thank you!Â
DevendraÂ
4863
1587
1386
1242
