Discovery 2025 R2: Skewness Max Value Input Error
    • fynn.voss
      Hi everyone, I am experiencing a strange input validation issue in Ansys Discovery 2025 R2 when trying to set the maximum Skewness value under Mesh Metric (Refine) settings for Fluid Flow simulations. The default value is 0.95. When I try to change it to 0.7, Discovery throws an error saying the value is greater than 1 – which obviously makes no sense for a value of 0.7. Interestingly, entering 0.1 works without any issue. It seems like any value between 0.1 and 0.95 triggers this incorrect validation error. I already tried: - Deleting the field completely and retyping the value - Using both comma and period as decimal separator - Restarting Discovery Has anyone experienced this before or knows a workaround? Is this a known bug in 2025 R2? Thanks in advance!
Viewing 0 reply threads
