Creating animation of unsteady Fluent DPM
    • scabo
      Hi
      I am running an unstedy Fluent simulation on HPC and trying to create an animation of particle positions via the command /solve/animate/objects create anim animate-on particle-tracks-1 storage-type hsf. It is creating the animation object but I cannot play it while I load the dat file back into Fluent. Also it is not writing any .cxa file in the dir. Is it not possible to create animations while running on HPC?
      thanks
    • SRP
      When running Fluent on HPC, you need to use the commands, please check user's guide here: 4.1. Starting Ansys Fluent-
    • scabo
      Hi-this link is not opening, demanding a lot of things via a form. Btw i have used the command written in my message above-is it something different you are talking about?
