Ansys Innovation Courses
Provide feedback or ask questions related to the Ansys Innovation Courses content.
Correction in a file
    • 1802039
      Can anyone kindly check and fix the problem in this file? - "https://ansys13.ansys.com/AnsysInnovationCourses/MBU/HeatTransfer/HeatTransferOverview/SE02ThermalAnalysisOfHeatPot.zip"
      Steel pot on a stove
      I just downloaded from innovation course and tried to rerun it. Nothing was changed, but I get error like - "An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Please see the Troubleshooting section of the Help System for more information.An internal solution magnitude limit was exceeded. (Node Number 2021, Body Solid, DOF TEMP) Please check your Environment for inappropriate load values or insufficient supports.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.  Please see the Troubleshooting section of the Help System for more information."
      Thank you
    • Ashish Khemka
      We are aware of this. Please wait, and we will be making the changes.
      Ashish Khemka
