February 6, 2025 at 3:47 pm
p.wilk
SubscriberHello guys,
I am using custom material properties in Engineering Data but for some reason when I run my simulation with that data i get following error:
I can't manage to figure out the error, do you have any ideas?
Those are the properties I defined:
I have tripplechecked every single tabular data, I dont have any duplicate temperatures in one table. -
February 11, 2025 at 3:14 pm
dlooman
Ansys EmployeeCould you provide screen shots of your tabular input? Sometimes it would be convenient to specify a step change in a property vs temperature, but it's not supported.
February 12, 2025 at 11:13 am
Akshay Singh
Ansys EmployeeHI, You can also check your dat file and search for keyword MPTEMP.
Check carefully as to where this command is associated.
dat file sends commands in a sequence so if you check a few lines near the problematic MPTEMP command, you will be able to pinpoint the cause of the error.-
February 17, 2025 at 10:18 am
February 17, 2025 at 7:35 pm
dlooman
Ansys EmployeeThose empty commands are to zero out the previous temperature table. There only needs to be one of them, but they aren't the problem. You didn't show all of your MPTEMP commands.
February 18, 2025 at 11:54 am
p.wilk
SubscriberYou are right, sorry. Here is all MPTEMP commands (its long sorry)
/com,*********** Send Materials ***********Temperature = 'TEMP' ! TemperatureMPTEMP,,,,,,,,MPTEMP,1,20MPTEMP,2,226.85MPTEMP,3,726.85MPTEMP,4,1226.85MPTEMP,5,1726.85MPTEMP,6,2226.85MPDATA,DENS,1, ,15700,15650,15525,15400,15275,15150, ! kg m^-3MPTEMP,,,,,,,,MPTEMP,,,,,,,,MPTEMP,1,-223.15MPTEMP,2,-173.15MPTEMP,3,-123.15MPTEMP,4,-73.15MPTEMP,5,-23.15MPTEMP,6,7.88860905221012e-31MPTEMP,7,7.88860905221012e-31MPTEMP,8,24.85MPTEMP,9,26.85MPTEMP,10,76.85MPTEMP,11,126.85MPTEMP,12,176.85MPTEMP,13,226.85MPTEMP,14,276.85MPTEMP,15,326.85MPTEMP,16,376.85MPTEMP,17,426.85MPTEMP,18,476.85MPTEMP,19,526.85MPTEMP,20,576.85MPTEMP,21,626.85MPTEMP,22,676.85MPTEMP,23,726.85MPTEMP,24,826.85MPTEMP,25,926.85MPTEMP,26,1026.85MPTEMP,27,1126.85MPTEMP,28,1226.85MPTEMP,29,1326.85MPTEMP,30,1426.85MPTEMP,31,1526.85MPTEMP,32,1626.85MPTEMP,33,1726.85MPTEMP,34,1926.85MPTEMP,35,2126.85MPTEMP,36,2326.85MPTEMP,37,2526.85MPTEMP,38,2726.85MPDATA,EX,1, ,706750000000,706750000000,706710000000,706550000000,706140000000,7.88860905221012e-31,MPDATA,EX,1, ,7.88860905221012e-31,705470000000,705430000000,704410000000,703090000000,701500000000,MPDATA,EX,1, ,699650000000,697590000000,695330000000,692900000000,690330000000,687620000000,MPDATA,EX,1, ,684790000000,681860000000,678830000000,675730000000,672550000000,665990000000,MPDATA,EX,1, ,659230000000,652280000000,645180000000,637970000000,630640000000,623230000000,MPDATA,EX,1, ,615730000000,608170000000,600560000000,585170000000,569630000000,553950000000,MPDATA,EX,1, ,538170000000,522310000000, ! PaMPTEMP,,,,,,,,MPTEMP,,,,,,,,MPTEMP,1,-223.15MPTEMP,2,-173.15MPTEMP,3,-123.15MPTEMP,4,-73.15MPTEMP,5,-23.15MPTEMP,6,7.88860905221012e-31MPTEMP,7,7.88860905221012e-31MPTEMP,8,24.85MPTEMP,9,26.85MPTEMP,10,76.85MPTEMP,11,126.85MPTEMP,12,176.85MPTEMP,13,226.85MPTEMP,14,276.85MPTEMP,15,326.85MPTEMP,16,376.85MPTEMP,17,426.85MPTEMP,18,476.85MPTEMP,19,526.85MPTEMP,20,576.85MPTEMP,21,626.85MPTEMP,22,676.85MPTEMP,23,726.85MPTEMP,24,826.85MPTEMP,25,926.85MPTEMP,26,1026.85MPTEMP,27,1126.85MPTEMP,28,1226.85MPTEMP,29,1326.85MPTEMP,30,1426.85MPTEMP,31,1526.85MPTEMP,32,1626.85MPTEMP,33,1726.85MPTEMP,34,1926.85MPTEMP,35,2126.85MPTEMP,36,2326.85MPTEMP,37,2526.85MPTEMP,38,2726.85MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,0.234,0.234,0.234,0.234,MPDATA,NUXY,1, ,0.234,0.234,MPTEMP,,,,,,,,MPTEMP,,,,,,,,MPTEMP,1,-223.15MPTEMP,2,-173.15MPTEMP,3,-123.15MPTEMP,4,-73.15MPTEMP,5,-23.15MPTEMP,6,24.85MPTEMP,7,26.85MPTEMP,8,76.85MPTEMP,9,126.85MPTEMP,10,176.85MPTEMP,11,226.85MPTEMP,12,276.85MPTEMP,13,326.85MPTEMP,14,376.85MPTEMP,15,426.85MPTEMP,16,476.85MPTEMP,17,526.85MPTEMP,18,576.85MPTEMP,19,626.85MPTEMP,20,676.85MPTEMP,21,726.85MPTEMP,22,826.85MPTEMP,23,926.85MPTEMP,24,1026.85MPTEMP,25,1126.85MPTEMP,26,1226.85MPTEMP,27,1326.85MPTEMP,28,1426.85MPTEMP,29,1526.85MPTEMP,30,1626.85MPTEMP,31,1726.85MPTEMP,32,1926.85MPTEMP,33,2126.85MPTEMP,34,2326.85MPTEMP,35,2526.85MPTEMP,36,2726.85MPDATA,C,1, ,15.93,66.94,104.56,135.15,160.68,180.54,MPDATA,C,1, ,181.35,197.39,208.52,216.74,223.17,228.43,MPDATA,C,1, ,232.82,236.65,240.07,243.13,245.94,248.54,MPDATA,C,1, ,251,253.34,255.54,259.62,263.45,267.03,MPDATA,C,1, ,270.4,273.61,276.63,279.49,282.24,284.85,MPDATA,C,1, ,287.35,291.94,296.03,299.7,302.92,305.73, ! J kg^-1 C^-1MPTEMP,,,,,,,,MPTEMP,,,,,,,,MPTEMP,1,-223.15MPTEMP,2,-173.15MPTEMP,3,-123.15MPTEMP,4,-73.15MPTEMP,5,-23.15MPTEMP,6,24.85MPTEMP,7,26.85MPTEMP,8,76.85MPTEMP,9,126.85MPTEMP,10,176.85MPTEMP,11,226.85MPTEMP,12,276.85MPTEMP,13,326.85MPTEMP,14,376.85MPTEMP,15,426.85MPTEMP,16,476.85MPTEMP,17,526.85MPTEMP,18,576.85MPTEMP,19,626.85MPTEMP,20,676.85MPTEMP,21,726.85MPTEMP,22,826.85MPTEMP,23,926.85MPTEMP,24,1026.85MPTEMP,25,1126.85MPTEMP,26,1226.85MPTEMP,27,1326.85MPTEMP,28,1426.85MPTEMP,29,1526.85MPTEMP,30,1626.85MPTEMP,31,1726.85MPTEMP,32,1926.85MPTEMP,33,2126.85MPTEMP,34,2326.85MPTEMP,35,2526.85MPTEMP,36,2726.85MPDATA,ALPX,1, ,2.25e-06,3.56e-06,5.51e-06,7.37e-06,8.92e-06,1.01e-05,MPDATA,ALPX,1, ,1.017e-05,1.117e-05,1.196e-05,1.26e-05,1.312e-05,1.355e-05,MPDATA,ALPX,1, ,1.391e-05,1.422e-05,1.45e-05,1.474e-05,1.496e-05,1.515e-05,MPDATA,ALPX,1, ,1.534e-05,1.551e-05,1.567e-05,1.598e-05,1.625e-05,1.651e-05,MPDATA,ALPX,1, ,1.676e-05,1.7e-05,1.724e-05,1.747e-05,1.771e-05,1.795e-05,MPDATA,ALPX,1, ,1.818e-05,1.867e-05,1.917e-05,1.97e-05,2.025e-05,2.082e-05, ! C^-1MPTEMP,,,,,,,,MPAMOD,1,20, ! CMPTEMP,,,,,,,,MPTEMP,1,0MPTEMP,2,200MPTEMP,3,400MPTEMP,4,600MPTEMP,5,800MPTEMP,6,1000MPDATA,KXX,1, ,93.62,73.4,64.89,55.32,51.06,48.94, ! W m^-1 C^-1MPTEMP,,,,,,,,MP,UVID,1,e58daecb-7460-453d-b09e-d460cc39f404
February 18, 2025 at 4:18 pm
dlooman
Ansys EmployeeThese temperatures appear to be identical:
3467
1057
1051
918
896
