September 12, 2025 at 11:06 am
tinsaegbehaga
SubscriberHi,
I’m running simulation on Static Structural and seeing unrealistic deformation. The model is a stack of thin-film layers with different thicknesses and material properties. I ran a thermal analysis on Thermal–Electric tool and imported those results into Static Structural to study thermal-expansion mismatch effects.
However, I’m getting a warning: “The maximum contact stiffness is too big.” and also the result I saw is not realistic. I tried adjusting the normal stiffness control from Programmable to Factor in specific contacts and tested different values, but the issue still persists.
Could anyone help me on this?
Thanks -
September 12, 2025 at 11:49 am
Subhash Tadala
Ansys EmployeeThis warning occurs when normal contact stiffness (FKN) is higher than 10^16.
Can you check if changing the unit system is helping to avoid this issue ?
- APDL, memory, solid
- Meaning of the error
3862
1414
1220
1118
1015
