November 3, 2025 at 1:16 pm
msalmaniaran
SubscriberHi,
I wish to simulate the whole RF energy harvesting system in Ansys Electronics, but I am not sure if I could co-simulate both the metasurface part and the rectification circuit part together in Ansys Circuit. The metasurface absorb the RF energy, simulated in HFSS, and then trasfers the energy to the rectifier for rectify this signal and make it DC.Â
I would appreciate any help with this matter.
Viewing 0 reply threads
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
