3D Design
3D Design
Bug when copying standard holes with cosmetic thread
    • Tim Dukes
      In 2025 SpaceClaim if you create a standard hole with a cosmetic thread and then try and use the move tool to copy it a certain distance you end up with multiple overlapping copies. See image below of the top no cosmetic thread added and the second one with.
    • Devendra Badgujar
      Hi Tim,
      With 2025 R2 version, I was not able to reproduce this. May be you can try the service pack of 2025 R2 and see if that helps.
      Devendra
