Birth and death
    • hasanilkerceliker
      I want to perform a paint removal process on CFRP material. I want to determine the surface temperature and material removal depth by moving the laser along one axis.
      The results I obtained are as follows. How should I proceed? The laser parameters I used are:
      Laser power: 50 W
      Wavelength: 1064 nm
      Frequency: 80 kHz
      Laser scanning speed: 100-1500 mm/s range
      I am trying to create using the element birth and death method (APDL).
Viewing 0 reply threads
