August 30, 2025 at 7:00 am
aneeshbhat
SubscriberGreetings,
I am not able to mesh perpendicular to the top surface. When I select both the surfaces together the mesher doesnt do any inflation. I have tried the Program Controlled option in "Mesh" tab with required settings, still no inflation.Â
For context: below geometry is for turbine flow passage and the suface marked "X" is of blade and "✓" marked surface is shorud.
Appreciate every help on this. Thanks.
PS: I know, turbogrid is there, but wanted to try with workbench mesh.
Viewing 0 reply threads
Ansys Innovation Space
1388
1188
1095
1015
