Ansys Free Student Software
Ansys Workbench Crash: Error 0xc0000374
    • Matt Ford
      My Ansys Workbench routinly crashes during analysis. When it does, I sometimes receive notification of "Ansys WBU.exe encountered a problem. A diagnostic file has been written: C:\Users\mford\AppData\Local\Temp\AnsysWBDumpFile.dmp"
      I am unable to locate that file. Looking through the event viewer the details I found are included below.
      I have already uninstalled and reinstalled and the issue remains, any help would be appreciated.
      Thank you
    • George Karnos
      Can you please open a Windows command prompt and run the command set and share the full output?
      • Matt Ford
        What command prompt and set are you referring to?
    • George Karnos
      In the Windows search on the Taskbar, type in:
      cmd
      When the Dos Command Prompt window opens, type in:
      set
      Copy all output (be sure to grab the info that scrolled off-screen)
      paste in a response
    • Matt Ford
      Here is the information, hope it helps narrow down the issues.
  • The topic ‘Ansys Workbench Crash: Error 0xc0000374’ is closed to new replies.
