March 18, 2026 at 8:37 am
david.danko
SubscriberHi, I’d like to ask what would be the best way to simulate a cylindrical triaxial test in ANSYS Rocky.
Problematic thing is, I need to apply a constant confining pressure on the particles from all sides. In reality we have a sealed membrane with vacuum inside, I am not sure what would be the best way to replicate the pressure in Rocky?
Thank you for any input.
March 25, 2026 at 2:24 pm
Jackson Gomes
Ansys EmployeeHi David,
You can approximate this in a couple of ways:
- 2-Way coupling with Ansys Mechanical: this is the most realistic option. You can model the membrane in Mechanical and let it apply the confining pressure through deformation: Ansys Rocky: 2-Way Structural Coupling with Mechanical - YouTube
- Motion frames with force-controlled boundaries: apply forces on the walls. For the lateral confinement, instead of a single cylinder, split it into multiple segments so you can better approximate a uniform radial pressure.
For more details, see the User Manual: Rocky User Manual
Hope this helps!Â
If you'd like to explore more learning materials about Rocky software, you can find them here: https://innovationspace.ansys.com/ais-rocky/
Warm Regards,
Jackson
March 30, 2026 at 9:23 am
david.danko
SubscriberHello,
thank you for the suggestions. The 2-Way coupling approach seems to work quite well and I will go on with this method.
5879
1306
