ANSYS Mesher Hyperbolic node distribution
    • Scott Ormiston
      Is it possible to get a two-sided hyperbolic node distribution in ANSYS Mesher.
      I would like to be able to set an edge sizing and specify that distribution with a first spacing size on each end.
    • Petros
      If you insert an Edge Sizing then in Advanced→Bias Type you can set it to have a two-sided hyperbolic node distribution. You can also set the appropriate Bias Factor based on the desired node spacing.
    • Scott Ormiston
      Thank you very much for your quick response. Do you mean that the Bias Type that looks like this:
      is two-sided hyperbolic?  Or is there another way to access the two-sided hyperbolic distribution?
      Also, is there a way of specifically setting the first spacing amount.  I will have no way of predicting the ratio of smallest to largest spacings (what I think
      Bias refers to). Is it supposed to be trial and error?  If so, how to I determine the first spacing size easily?
      Thanks.
    • Petros
      Yes that is a 2-sided hyperbolic bias. If this is a wall and you want accurate modeling of the first spacing, maybe using the Inflation (RMB Mesh→Insert→Inflation) option is a better approach. This has the capability to specify First Layer Thickness.
