Ansys Mechanical Error When ANS_USER_PATH is Set
    • eddy.lee
      I have compiled Ansys subroutine to use for a transient thermal model that I am trying to run. To access the subroutine, I set the ANS_USER_PATH pointing to the directory I have my libraries in. When I try to solve my model, I get "An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information". This only happens when I have ANS_USER_PATH set. Even if the directory is empty, I get this error. It seems to be happening during pre-processing before the analysis even begins, once Ansys sets the ANS_USER_PATH.
      Based on the troubleshooting:
      1. I believe I have enough memory since I am able to run similar sized models without ANS_USER_PATH set.
      2. I have more than enough storage on my drive.
      3. I have uninstalled and reinstalled Ansys 25 R1 to no avail.
      4. I am running all the models on my C drive.
      5. I have tried placing my subroutines in different locations, such as in the C: folder, the Program Files folder, even my desktop.
      The compiled subroutines works on all other computers as well so I don't believe it's a compiling issue.
    • Shashidhar Reddy
      Can you please go through the following link? Some root causes are listed here. You may get some help
      26.1.8. An Error Occurred While Starting the Solver Module
