August 31, 2026 at 10:29 pm
deeps
SubscriberHello,
I am trying to solve a conjuage heat transfer problem involving high speed flow - which requires the use of density-based solver. The material I am using has anisotropic properties, but anisotropy is not supported in density-based solver (mentioned in Fluent Documentation). Is there any workaround for this?
Thank you. -
September 2, 2026 at 10:54 am
Channel PartnerIf it's covered as a limitation then, no, there isn't a workaround. However... How high a speed are you looking at?Â
