Air Heat Transfer Coefficient – SteadyStateThermal Simulation – ANSYS Mechanical
    • 318661
      I would need some help in order to understand better this situation.
      I'm a master's degree student, and I have to perform a thermal simulation of a simple electrical component, a resistor. I already made some measurements in reality: I put the resistor on a wood plate, supported by some little "rubber feet", then I fed it with certain current and voltage, in order to get a certain power (4.81 W) and I placed several thermocouples in order to get real temperatures of the chassis of the resistor (which is made by aluminum). (I took temperature on the uppersurface and on one of the flanks of the resistor).
      Then my aim is to perform a simulation (steady state) on Ansys Mechanical that should be able to reproduce the real behaviour of the system, that is to say it has to match the temperature measured during the experiment with the temperature which comes from the simulation. In order to do this, I built up a 3D CAD model, as you can see in the pictures above, and then I used as thermal loads:
      • Internal heat generation: I used a value such that, when it is multiplied by the volume of the body of the resistor (I considered it as a unique body all made by aluminum), gives a certain power (4.81W)
      • Convection: I used this boundary condition on all the surfaces in contact with air, so all the external surfaces of the resistor, the rubber feets and the wood plate
      Here we get to the point: when I have to model air, simplifying it as a convection boundary condition, I need to insert the "film coefficient", which is the htc of the air, and the ambient temperature, which is the temperature of the air far from the contact surface (25°C more or less).
      At first, I tried with a constant htc used for all the surfaces, and I found a value (after many tries) able to match the simulated temperature with the measured one. The problem is that obviously this result lacks of generality, because if I try to use the same value of htc for another resistor, maybe bigger or smaller or with a different shape, even if the power generated is the same (4.81 W), I'm not able to match results and experiments.
      Then, I guess that actually htc of air depends on many parameters, such as velocity of the fluid, geometry, temperature difference ecc.
      But then the question is, how can I estimate or measure in reality a proper htc for each case?
      I saw that there is the possibility to specify a temperature dependent film coefficient in the Convection boundary condition, but still I don't know hot to find a proper correlation. Could someone please help me?
      P.S: I also know that maybe a CFD analysis should be better, because it directly solves for fluid properties, and he can understand how the heat is transfered from the solid component to the air without specifying an htc or something like that. But still I want to understand if this simple problem, and maybe more complex problems similar to this one, can be solved also with a FEM method using Ansys Mechanical steady state thermal simulation or not.
    • dlooman
      It appears you have mainly natural convection (no fan blowing air over the bodies.)  So it would be interesting to see if the handbook values for natural convection produce the correct temperature.   The fly-out menu for the film coefficient in Mechanical has an option to "Import Temperature Dependent..."  One of the temperature dependent options is for stagnant air and a horizontal cylinder.  This option uses the formula below.  It could be close to your case.
      Stagnant Air, Horizontal Cylinder, Turbulent Case. Using h = 1.24(Tw-Tb)**1/3, GrPr greater than 10e9. Ref. Holman, "Heat Transfer," McGraw Hill, 5th ed., p285.
      • 318661
        Good morning, thank you so much for the help! 🙏
        Yes, in my case there is only natural convection; I tried to use the temperature dependent values for the film coefficient (Stagnant Air - Horizontal Cylinder fot the resistor itself, Vertical Planes for vertical surfaces of the wood plate, Simplified for the horizontal surface of the wood plate) but still I'm not able to reach my results. The measured temperature of the resistor is 130 °C, while from the simulation it reaches 250 °C more or less.
        I watched a lecture from Ansys Innovation Space
        (https://innovationspace.ansys.com/courses/courses/thermal-convection-in-heat-transfer/lessons/film-coefficient-lesson-2/)
        Here they state that the film coefficient of the air can be estimated analytically, but I guess it is not my case since I have a complex geometry, not a simplified one). Another way to find it could be doing experiments, but actually I can't do them, finally I could use a CFD analysis to extrapolate the htc and give it to ANSYS Mechanical. Do you think there are also other ways? Because I don't think that for such a simple model I need experiments or CFD.
        The only idea I have in mind is to simplify the geometry of my body making it as a simple cylinder (keeping the same volume and the same surface of the original body), and try again to use the handbook values already stored in ANSYS. What do you think about it?
