Embedded Software
Embedded Software
Topics related to SCADE Suite, SCADE Display, SCADE One and more.
Access operator output by parameter name in text operator body
    • Flix
      In ScadeOne, you can access operator output by specifying the output parameter name in the adaptation on the wite connection.
      Is this possible within the text representation as well? I could only find you can access the output by position, i.e. op().(1) for the first output. It is neither allowed to do op().out1 nor op().(out1).
    • Benjamin Descorps
      The output group of a text instance (of the form ‘op()’) is considered positional. So, indeed, you can only access outputs by their index (op().(1)). For an instance in a block diagram, the output group can be either positional or named.
      In practice, you should prefer a direct access to the equation x, out1, z = op() where you can only get the output you are interested in. Example:
      _, out1,_=op() or _,out1,..=op()
      Hope this helps,
      Benjamin
