January 16, 2026 at 4:55 pm
lufan.zhou
SubscriberI was simulating two simulations: Maxwell 3D and 2D cylindrical RZ in the Eddy Current solver. I found that the AC resistance is different in these two simulations when I am simulating planar windings with two layers. I set the mesh configuration in 3D to accurate. It is a simple two-layer winding, and I didn’t simulate it well.
Could you help with this issue?
I will attach images of the resistance and the model in 3D and 2D.
January 20, 2026 at 6:36 pm
MirandaH
Ansys EmployeeIn order to better understand this comparison, how was the excitation assigned in the 2D design? Is the winding solid or stranded? How about mesh quality from both designs? -
January 21, 2026 at 9:07 am
lufan.zhou
SubscriberIn order to better understand this comparison,
How was the excitation assigned in the 2D design?
1 A for both.Is the winding solid or stranded?
Solid for both.How about the mesh quality for both designs?
The 2D design is the same, changing only the mesh quality, and in 3D I set a better mesh using a length mesh of 6 mm.
I will attach the mesh plots of the simulations in 2D and 3D.
January 22, 2026 at 2:02 pm
MirandaH
Ansys EmployeeThe mesh might not be fine enough to capture ununiformed current distribution when frequency gets higher. Please consider to use skin depth mesh operation to calculate the skin depth at each frequency.
January 22, 2026 at 4:55 pm
5069
1797
1387
1248
