Ansys Learning Forum Forums AIS Japan ANSYS製品 Technical Support Inquiry: APDL /INPUT command executing incorrect script conten Reply To: Technical Support Inquiry: APDL /INPUT command executing incorrect script conten
mrife
"After extensive debugging with an AI coding partner...." I would not expect  any AI/LLM to give 100% correct APDL code at this point (aside from one command answers).  Can you show us the beginning of the corrected APDL script.
