Ansys Learning Forum Forums AIS Japan ANSYS製品 Ansys AutodynのSteinberg Guinanに関して Reply To: Ansys AutodynのSteinberg Guinanに関して
Chris Quan
If you are referring to Initial Yield Stress of a material, where effective plastic strain is equal to 0. Yes, you can adjust its value to match the value you have.
However, fo other parameters that are related to plastic hardening and further yielding, I wouldn't suggest you to adjust their values, since they were derived from experimental and analytical studies. These parameters work together to describe the material hardening behavior.
