Ansys Learning Forum › Forums › AIS Japan › 構造 › エンジニアリングデータ内の直交異方性応力限界について › Reply To: エンジニアリングデータ内の直交異方性応力限界について
armin.abedini
You are right.
When using LS-DYNA in the workbench, it is recommended to first insert the LS-DYNA analysis system to the Project Schematic and then open Engineering Data. This way only filtered material models supported by the LS-DYNA solver will be shown.
