Ansys Learning Forum › Forums › AIS China › 结构 › beam188单元的剪切应变 › Reply To: beam188单元的剪切应变
userzff067
No, I specify that I must use beam188 elements, and the element used in the example you gave is SHELL281. I want to use beam188 elements to obtain the shear strain of the cross section, which is a constant. It can be easily obtained through theory, but I must use the beam188 element of ANSYS to obtain it
