Ansys Learning Forum Forums AIS Japan 構造 LS-DYNA MAT_Wood 定義について Reply To: LS-DYNA MAT_Wood 定義について
Ram Gopisetti
Hi Yuu0910,
You are right about implementing unsupported material models in LSDYNA WB.
The material card information should be modeled by performing some experiments as per the paper in the link https://www.dynalook.com/conferences/16th-international-ls-dyna-conference/constitutive-modeling-t7-1/t7-1-d-constitutive-modeling-115.pdf
or taken from the published literature sources and an example source on Mapel and Ash woods Material models are described in the link https://www.researchgate.net/publication/328971285_Characterization_of_Maple_and_Ash_Material_Properties_for_the_Finite_Element_Modeling_of_Wood_Baseball_Bats?_tp=eyJjb250ZXh0Ijp7ImZpcnN0UGFnZSI6Il9kaXJlY3QiLCJwYWdlIjoiX2RpcmVjdCJ9fQ
Make sure you follow consistent units with LSDYNA WB.
Cheers, Ram
