Ansys Learning Forum Forums AIS Japan 流体 HexCoreのピール層を削除できるか Reply To: HexCoreのピール層を削除できるか
Federico
Hello Kota,
From Fluent Meshing 22R2, you can now enable MultiZone meshing in the Watertight goemetry workflow from the Describe the Geometry task. Just click Yes for the question Use MultiZone meshing and the corresponding tasks will be enabled in your workflow.
You will need to identify Source and/or Target zones to define the sweep directions. These zones should be the inlet and/or outlet of the circular tube. You then have the option to choose Map/Pave methods and/or to have a fixed sweep size. I invite you to try them to see their behavior.
I hope this helps!
