Understanding Transformer Tests and Equivalent Circuits — Lesson 2
This lesson covers the process of performing two simple tests on a transformer to determine its equivalent circuit. The first test is the open circuit test, carried out from the low voltage (LV) side, and the second is the short circuit test, performed from the high voltage (HV) side. The lesson explains why these tests are conducted from these specific sides and how the results can be used to draw the equivalent circuit of a transformer. It also discusses the importance of carrying out these tests under rated conditions to ensure both the core and copper losses are at their rated values.
Video Highlights
01:27 - Explanation of the wattmeter reading during the short circuit test and the concept of copper loss and core loss
06:58 - Explanation of the process of transforming RE2 to RE1 and XE 2 to XE 1 in the equivalent circuit
14:35 - Explanation of the process of carrying out the open circuit test and short circuit test for a transformer with a large voltage rating
32:01 - Discussion on the operation of a transformer under full load condition and the presence of both core loss and copper loss at their rated values
34:54 - Conclusion of the lecture and a preview of the next class
Key Takeaways
  • The open circuit and short circuit tests are crucial for determining the equivalent circuit of a transformer.
  • The open circuit test is carried out from the LV side, while the short circuit test is performed from the HV side.
  • During the open circuit test, the core loss is at its rated value, while during the short circuit test, the copper loss is at its rated value.
  • When a transformer operates under full load conditions, both the core and copper losses are at their rated values.
  • It's essential to carry out these tests under rated conditions to ensure the transformer is operating optimally.
