This lesson covers the concept of transformer regulation and equivalent circuits. It explains how to obtain an approximate expression for the regulation of a transformer. The lesson also reviews the equivalent circuit and how it can be drawn in different ways with respect to the primary and secondary side. It further discusses the concept of an ideal transformer and how neglecting the no-load current can lead to an approximate equivalent circuit. The lesson also provides a detailed explanation of how to calculate the regulation using the equivalent circuit referred to the primary side. An example of a well-designed transformer is used to illustrate the concept of regulation.
00:25 - Explanation of the goal of the lecture
03:14 - Discussion on the neglect of the no load current
10:43 - Explanation of the equivalent circuit referred to the primary side
18:29 - Discussion on the calculation of the regulation
29:11 - Explanation of the use of the expression for regulation
