Inclining Experiment — Lesson 3
This lesson covers the concept of an inclining experiment, a crucial test conducted during the construction of a vessel. The primary goal of this experiment is to calculate the position of the center of gravity of the vessel (KG), but the actual calculation performed during the experiment is GM. The lesson explains the process of the inclining experiment, where a pendulum is hung from a point on the vessel and a small weight is shifted from one side to the other, causing the vessel to incline. The lesson also discusses the importance of stability calculations and the role of hydrostatic data in these calculations. It further explains the concept of Bonjean curves and their role in calculating the displacement of a vessel.
Video Highlights
0:18 – Introduction to Inclining Experiment and its importance in ship construction
1:38 – Discussion on the calculation of KG (position of the center of gravity of the vessel) and GM (metacentric height)
13:20 – Explanation of the concept of light ship weight and dead weight
29:38 – Discussion on the impact of increasing GM (metacentric height) on the ship's stability and comfort
33:22 – Introduction to Hydrostatic Curves and explanation of principle particulars of the ship
42:53 – Explanation of the Bonjean Curve and its importance in calculating the displacement of the ship
Key Takeaways
- An inclining experiment is conducted to calculate the position of the center of gravity of a vessel (KG).
- The actual calculation performed during the experiment is GM, which is then used to derive KG.
- The experiment involves hanging a pendulum from a point on the vessel and shifting a small weight from one side to the other, causing the vessel to incline.
- Stability calculations are crucial in the construction of a vessel.
- Bonjean curves are used to calculate the displacement of a vessel.
