This lesson covers the principles and equations of rotational viscometers, specifically focusing on parallel disk rheometers. It delves into the working principles of these devices, their applications in the rubber industry, and how they can be used to measure the rheology of non-Newtonian fluids. The lesson also explains how to calculate shear stress, shear rate, and normal stress differences using these rheometers. It further discusses the impact of factors like gap size and rotational speed on these measurements. An example problem is solved to illustrate the application of these concepts in real-world scenarios.
01:50 - Discussion on the effect of the gap between the two cylinders on the shear rate
10:04 - Explanation of the momentum equations used in parallel disk rheometers
18:40 - Derivation of the velocity profile in parallel disk rheometers
31:34 - Explanation of how to calculate shear stress, shear rate, and normal stress differences using parallel disk rheometers
37:31 - Example problem demonstrating how to use the equations derived for parallel disk rheometers
