This lesson covers the numerical implementation of Duhamel's Integral in MATLAB to solve for the response due to arbitrary loading in a system. The lesson begins with a recap of the theory behind Duhamel's Integral and the expression for the impulse response function. The instructor then demonstrates how to numerically evaluate the response using MATLAB, including defining the mass, stiffness, and critical damping ratio of the system, and applying a forcing function. The lesson also includes a practical example of applying Duhamel's Integral to an earthquake ground motion, demonstrating how to plot the ground acceleration and the resulting response.
Explanation of the derived expression for the daml integral - 0:31
Discussion on the stiffness damping mass and the degrees of freedom - 1:16
Explanation of the impulse response function - 2:33
Explanation of the forcing function and its numerical evaluation - 3:18
Discussion on the duhamel integral and its simplification - 3:47
Explanation of the trapezoidal rule for evaluating the integral - 7:31
Demonstration of writing a function file for the daml integral in MATLAB - 9:57
Explanation of the natural frequency and the damped natural frequency - 10:56
Demonstration of initializing the displacement at the output - 12:03
Explanation of the trapezoidal rule for evaluating the integral - 17:29
Demonstration of plotting the function and the response - 22:30
Discussion on the L Central earthquake ground motion as an arbitrary forcing function - 26:09
Demonstration of plotting the L Central ground motion and the response from the duhamel integral - 27:55
- Duhamel's Integral is a powerful tool for solving for the response due to arbitrary loading in a system.
- The impulse response function is a key component in the calculation of Duhamel's Integral.
- MATLAB can be used to numerically evaluate Duhamel's Integral, allowing for the analysis of complex systems and loading conditions.
- The lesson provides practical application of Duhamel's Integral to real-world scenarios, such as earthquake ground motion.
