Understanding the Drift Flux Model-2 — Lesson 2
This lesson covers the concept of chocked flow condition for homogeneous flow. It explains the conditions under which this phenomenon occurs and how it affects the flow rate. The lesson also discusses the significance of the denominator in the homogeneous flow situation and how it corresponds to the Mach This lesson covers the concept of the drift flux model, its advantages, and how it modifies different mixture parameters such as void fraction and mixture density. The lesson also explains how the drift flux model can predict the hydrodynamics of two-phase mixed flows and transitional flows more accurately. It further discusses the different ways to estimate J 2 1 using kinematic constitutive equations and the two approaches to find out the kinematic constitutive equation to estimate J 2 1. The lesson concludes with the explanation of how to solve the equations of the drift flux model graphically.
Video Highlights
00:18 - Introduction to the drift flux model and its advantages
07:02 - Discussion on the factors influencing the kinematic and mechanical state between the two phases
33:59 - Explanation of the balance between fluid dynamic drag and buoyancy in the absence of wall effects
20:20 - Discussion on the transformation of forces per unit volume of individual phase to per unit volume of total flow field
51:18 - Explanation of the two limiting conditions for using the drift velocity equation
Key Takeaways
- The drift flux model is a useful tool for predicting the hydrodynamics of two-phase mixed flows and transitional flows.
- The model modifies different mixture parameters such as void fraction and mixture density.
- There are two approaches to estimate J 2 1 using kinematic constitutive equations.
- The first approach involves considering the mixture as a whole and applying various constitutive laws to the mixture.
- The second approach involves considering the two fluid model and obtaining the necessary constitutive equations by reduction of the two fluid model.
- The equations of the drift flux model can be solved graphically, which allows for a better understanding of the model's behavior.
