This lesson covers the testing and efficiency calculation of Direct Current (DC) machines. It delves into the Swinburne test, a no-load test used to predict the efficiency and performance of a machine. The lesson also discusses the limitations of the Swinburne test and introduces an alternative test that involves two mechanically coupled machines operating as a shunt motor and a generator. The lesson further explains the field test carried out for DC series motors. It also provides a detailed explanation of how to calculate the efficiency of a motor and a generator. The lesson concludes with the condition for maximum efficiency in a shunt motor.
01:52 - Discussion on the concept of 'phantom loading' in the context of testing DC machines
14:02 - Calculation of the efficiency of the motor and the generator in the field test
22:25 - Discussion on the condition for maximum efficiency in a transformer
25:48 - Explanation of the condition for maximum efficiency in a shunt motor
32:05 - Conclusion of the lecture and introduction to the next class topic
