This lesson covers the concept of compressible flow, primarily focusing on its application in aerospace and mechanical engineering. It discusses the significance of compressible flow in various scenarios such as flow through nozzles, turbomachinery blade passages, diffusers, and external aerodynamics. The lesson also explains the difference between compressible fluid and compressible flow, and introduces the concept of Mach number as a measure of compressibility. It further elaborates on the impact of compressibility in different flow fields and provides a guideline to determine when compressibility effects are significant. For instance, if the Mach number exceeds 0.3, compressibility effects may be expected to be significant.
01:08 - Importance of gas dynamics of refrigerants
08:22 - Comparison of isothermal compressibility of water and air
13:50 - Use of Mach number as a criterion to determine if compressibility effects are significant
16:45 - Explanation of how speed of sound links to compressibility
18:10 - Guideline for when compressibility effects may be significant based on Mach number
- Compressible flows are encountered in many applications, especially in aerospace and mechanical engineering.
- The working substance for aerospace engineers is air, while for mechanical engineers, it can be air, steam, or refrigerants.
- Compressibility is defined as the change in specific volume due to a change in pressure.
- The Mach number, which is the ratio of the actual speed in the flow field to the speed of sound at that location, is used as a measure of compressibility.
- Compressibility effects may be significant when the Mach number exceeds 0.3.
