Note: This tutorial has videos. If you are in a computer lab, make sure to have head phones.
Let's revisit the pipe flow example considered in the previous exercise. As before, the inlet velocity is 1 m/s, the fluid exhausts into the ambient atmosphere and the density is 1 kg/m3. For µ = 2 x 10 -5 kg/(ms), the Reynolds number based on the pipe diameter and average velocity at the inlet is
This change of viscosity has taken us from a Reynolds number of 100 to 10,000. At this Reynolds number, the flow is usually completely turbulent.
We'll solve this problem numerically using Ansys Fluent. Among the results we'll look at are the centerline velocity, the skin friction coefficient, and the axial velocity profile at the outlet.
