Consider fluid flowing through a cylindrical pipe of diameter D = 0.0127 m and length L = 5D = 0.0635 m. The bulk velocity at the pipe inlet is Ubulk = 6.58 m/s. Let us consider the case where the density of the fluid is constant. Take density ρ = 1.331 kg/m3 and coefficient of viscosity µ = 2.34 x 10-5 kg/(ms). The Reynolds number, Re, based on the pipe diameter and the bulk velocity is
$\text{Re} = \frac{\rho U_{\text{bulk}}D}{\mu} \approx 4750$
Solve the above fluid flow problem using the LES capability in Ansys Fluent via Ansys Workbench. Plot the mean and the root mean square velocities versus the radial distance at a particular x/D downstream of the inlet. Compare the mean velocity obtained from the LES simulation with the mean velocity obtained using the k-ε model.
