The Arbitrary Reference Frame — Lesson 1
This lesson covers the transformation of arbitrary reference frames in the modeling and analysis of machines. It explains how the speed of rotation can be adjusted to be anything, including the stationary reference frame, synchronous speed, or rotor speed. The lesson further discusses the transformation of the stationary reference frame to the rotor side, leading to the creation of a pseudo stationary reference frame for the rotor. It also delves into the concept of the operational impedance matrix and how it multiplies the vector of currents. The lesson concludes with the exploration of the implications of referring to a rotating frame at synchronous speed, rotor speed, or zero speed.
Video Highlights
00:11 - Introduction and Stationary reference frame
04:57 - Explanation of the operational impedance matrix
23:16 - Discussion on the transformation of the alpha and beta reference frame to the ID and IQ reference frame
40:53 - Discussion on the machine description
Key Takeaways
- The transformation of the stationary reference frame to the rotor side creates a pseudo stationary reference frame for the rotor.
- The operational impedance matrix multiplies the vector of currents to provide a comprehensive machine description.
- Referring to a rotating frame at synchronous speed results in the excitations and responses being DC quantities, which is beneficial for control system design.
- Referring to a rotating frame at rotor speed makes all the MMFs in the air gap appear to be rotating at slip frequency.
- Referring to a rotating frame at zero speed means the excitations are all at supply frequency.
