How to switch off the Kato Launder production limiter when using the Ansys CFX Transition Model?
The Ansys CFX Transition Model by default uses the Kato Launder formulation production limiter for the turbulence equations. This formulation is hard-coded in the algorithm. This solution gives a method to indirectly switch off the production limiter.
For more details, refer to this document.
