How to switch off variable time stepping using TUI? Getting following error: Error: received a fatal signal (Segmentation fault); Variable time stepping is available only for the VOF and Eulerian Multiphase model. Changing the time stepping method to Fixed
The following errors can occur if it is not switched off for non-VOF and Eulerian Multiphase problems. Error: received a fatal signal (Segmentation fault); Variable time stepping is available only for the VOF and Eulerian Multiphase model. Changing the time stepping method to Fixed.
To do this please use following command:
/solve/set/transient-controls
Note: This command is for Multiphase models except wet steam.
