Resolving Read_Grid_Section Error in Ansys Fluent
Getting following error while opening case file in Ansys Fluent: Error: Read_Grid_Section
Sometimes case file may be corrupt and gives this error while reading in Ansys Fluent.
The workaround to get this file in Ansys Fluent is as follows:
Please read case file in Ansys Fluent Meshing. You can launch Ansys Fluent Meshing using 'Meshing Mode' in Ansys Fluent launcher.
Once file is read in Ansys Fluent Meshing, please use switch to solution option to get into Ansys Fluent Solver environment.
