Semi Implicit Solver Technology — Lesson 7
Regarding Semi Implicit Solver Technology, how many criteria are available for controlling transition from the semi-implicit solution phase back to the implicit solution phase?
Only the ETOI option, (see SEMIIMPLICIT command) which defines the max time to spend in the semi-implicit phase, is available to users for controlling the transition from the semi-implicit solution phase to the implicit solution phase.
